-   -   ratio (http://www.hotrodders.com/forum/ratio-100760.html)
ict55chevy 10-21-2006 09:08 AM
ratio
I need to know the gear ratio in the stock 55 powerglide rearend.
thanks tc
gilby246 10-21-2006 09:30 AM
well...... a powerglides gear ratio is
1st - 1.82
2nd - 1.1
ict55chevy 10-21-2006 12:26 PM
ratio
I found the answer in some of my old chev books, and the rear end is 3.55.1 with the powerglide.
poncho62 10-21-2006 01:38 PM
Quite possible......many ratios were available. Lots of powerglides also used 3.36 rears too.
matt167 10-21-2006 05:13 PM
yep, poncho's got it. b4 1955, there was 2 gear ratio's 4.10's for 3spd manuals and 3.55's for the PG's, but in '55 when the V8 came out, many ratio's were available.
rj57 10-21-2006 05:21 PM
A stock '55 with powerglide would have got a 3:36, possibly a 3:55 rear end.
There was some change between '56 and '57 so it is possible the '55/56 got a 3:55 rear.
I know for a fact my '57 with original 283, powerglide has a 3:36 rear in it.
