Ratio Chart is this correct? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 03:42 PM
motivegear dot com has a gear ratio chart that shows at 55MPH the engine RPM range from 2050-2400RPMs for cars geared for cruising instead of stoplights. With a 29in time that gives a 3.20 to 3.90 ratio.
Why question is this assuming no Overdrive? (I think not)
If I want a 5,000Lbs car to cruise the interstate, not smoke tires it looks I need 3.42 to 3.73 gears.
But I have a LS1 -4L60e (.75 overdrive) So:
3.90 = 2.93 = 1875RPM @ 55
3.73 = 2.78 = 1745RPM @ 55
3.55 = 2.66 = 1715RPM @ 55
3.50 = 2.63 = 1700RPM @ 55
I have heard it is better to run a engine 100 RPMs too high than 100 RPMs too low- The engine noise and lower MPG are nothing compared to an engine that luggs at all times.
I had planned on 9in Ford with 3.50 or an Explorer with 3.55-- Should I look for 3.73 or 3.90?
I have a 62 Chrysler with 2.92 gears and love it (4,200Lbs) cruises great and barks going into 2nd with stock 413 engine...
Thanks for thoughts!
Charles
Old 03-18-2012, 03:54 PM
LATECH's Avatar
Last explorer diff I saw installed had a 4.10 ratio, multiply X .75 and you come up at like 3.08. That would be perfect. IMHO
i think 2200 at 60 mph would be better, not 1850 or whatever. That is too low to be in the optimum power making rpm range.JMO
Old 03-18-2012, 04:59 PM
Wiki Edits: 31
3.73 and 4.10 are both common expo ratios.
Old 03-18-2012, 07:06 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
3.73 is a very common exploder ratio
Old 03-19-2012, 07:43 PM
So am I reading this chart right?
http://www.motivegear.com/pages/charts/CHART.pdf
I am just shocked I would be putting a 3.73 or a 4.10 in a cruiser that I wanted to get good gas mileage.... If so that is cool, just doesnt sound right...
-Charles
Old 03-19-2012, 08:00 PM
LATECH's Avatar
3.73 -4.10 is what the charts shows for a 29 inch tire to be in the optimum rpm range for power and economy.
The overdrive gives you the stoplight to stoplight ratios in the first 3 gears and gives the economy in overdrive.
valve adjusters bottom out before lash is correct how do u find correct pushrod lengt brandon meek Engine 3 02-03-2011 03:58 PM
Compression Ratio Chart jcclark Engine 4 04-29-2007 02:02 PM
9:1 or 9.8:1 Which is the correct Compression ratio? Houman SS '70 Engine 6 05-01-2005 08:24 AM
Correct Gear Ratio MrRedDogSF Transmission - Rearend 11 04-29-2005 09:37 PM
correct air/fuel ratio 68chevelle_ss Engine 17 09-08-2004 10:15 PM
