A RatRod type frame question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2009, 10:15 AM
Although i could build a Frame, i dont feel my skill knowledge is that great, so i was wondering what types of frames Could i use? could i use a normal S10 rolling frame like an 80s ETC Or would i be better off with something much older and harder to find?
i was just curious
Old 08-11-2009, 09:15 PM
cboy's Avatar
Last journal entry: Finished
Use the search function (found near the top of the page) and enter terms such as "mini truck chassis" or "mini truck frame" and you'll get a ton of prior threads where this has been discussed in great detail. Many pictures, many opinions, many ideas.
Always learning...and sharing what I've learned.
Old 08-12-2009, 07:17 AM
Last journal entry: More painting pics
i was just curious
Hi
There is a book by Tex Smith called 'How to build Hot Rod Chassis' that I found useful, there is a section in there on modifying other frames. Although it is mainly about constructing them from scratch.
If you are fairly flexible on position and types of engines, trans, suspension etc. or will be using the same engine and running gear as the frame, modifying it might be a good way to go.
But if you have particular ideas on what you are going to use and will be doing a lot of modifying don't completely discount the idea of constructing a frame. You will be using similar skills modifying a frame as building one.
1953 Buick Sub Frame Question a1957chevy Suspension - Brakes - Steering 4 08-04-2009 03:31 PM
frame question 79z28 Body - Exterior 7 09-21-2008 12:03 PM
frame question wanabuildarod Hotrodding Basics 3 09-10-2008 03:47 AM
Frame question.. APalusky Hotrodding Basics 2 11-18-2006 09:01 AM
Frame "cleaning" question FiddyFour Customline Suspension - Brakes - Steering 4 11-23-2004 06:43 PM
