Rattle can spray for leather seats?
Do you recommend leather seat re-coloring with rattle can spray?
There are several reputable stores like Tandy Leather etc that sells rattle can leather spray color and they all brag about how good it sticks, that it don't crack or peel etc. Is it really that good? Any of you tested it and how does it look after some use? I have a pair of light brown leather seats that I'm planning to use in my hotrod, but i would like to paint them dark brown. I know there ar professionals that can do this, but that's out of my budget. But if it is a rather large risk for destroying the seats with cracking, peeling paint, I'd rather make the whole interior in light brown instead. I haven't bought any leather for the rest of the interior yet. |
Just like painting, the secret is in the preparation. If you clean the leather correctly, whatever you use will adhere and stay there. Your best bets are SEM Sure Coat and SEM Classic Coat. Classic Coat is aerosols, but there is no dark brown, the colors are matched to interior colors from car manufacturers. Sure Coat is water based and has to be mixed and sprayed with spraying equipment, but any color is possible. Check out this thread for re-coloring leather: CLICK HERE Here is the SEM web site regarding Sure Coat: CLICK HERE
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
I hope this helps! Chris |
Personally, I would never try to completely color leather seats, especially if the seats were not brand new. Leather needs to breathe to maintain its character, and that won't happen if you cover the top layer with something. I would do the same thing......match the rest of the interior to the seats. JMHO, do what you want.
If you use SEM products, clean it with what they recommend, which is SEM Soap followed by SEM Plastic/Leather prep. Follow the instructions to the letter.
SEM refinishing system works great. Have used it for panel matching for 20 years. I have disclosed it to customers when matching original leather panels were either impossible to get or too expensive to make the job cost effective to the owner. I have never had a complaint or an issue.
90% OEM Leather is top coated with a kind Clear Vinyl to add durabilty and to match surrounding Vinyls. Like it was said before use must use the total package as directed by the instructions. Use the prescribed prep solvent, it is a mixture of MEK and other prepping chemicals that etch the top coating and allow for color adhesion. If done wrong you will have a short term solution and another problem. |
| Recent Interior posts with photos |
| low priced spray gun/detail gun for primer/base/clear and ghost flames | jrmy_1 | Body - Exterior | 15 | 06-08-2008 06:38 AM |
| Titanium Vavles w/Iron Seats?? | Delirious2000 | Engine | 5 | 02-19-2006 09:58 PM |
| Mounting Bucket Seats! | SMF Speed&Custom | Interior | 2 | 08-19-2005 11:14 AM |
| Which Racing Seats Should I Get? | nightrain_rod | Interior | 7 | 04-08-2005 09:40 PM |
| I'm good with a spray can.... what am i doing wrong! | harrington | Body - Exterior | 21 | 04-25-2004 01:28 PM |
