rawl diode module - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2010, 08:34 AM
rawl diode module
im putting an engine and trans (350tbi/700r4) from an 86 pickup into an 83 camaro. i cant find a description or picture of the rawl diode module. is it required for everything to work right? does anyone have a pic of it? thanks
Old 03-14-2010, 11:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No picture, but follow the ppl/wht wire from the TCC solenoid and it will be at the end of that wire.
Maybe explain what is going on in a more general way and possibly more help might be offered...
Old 03-14-2010, 01:14 PM
i dont have the truck. i bought just engine trans ecu and wire harness. the wire is solid purple no white strip. tcc plug has three wires, light blue, purple, and tan/white. tan/white and light blue both go to ecu, purple stops where it would have gone into the cab of the truck. the rest of the wire harness is made up i just need to know what to do with the purple wire from tcc.
Old 03-14-2010, 01:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds like something to pick up from a junk yard. New, something like that could be some money.
Old 03-14-2010, 01:38 PM
will it drive properly without it? if not i guess ill have to make a trip to pullapart
Old 03-14-2010, 01:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My guess is no, but then I've never tried it. I'd want to reinstall it, if possible.
Good luck.
TH 350 vacuum module dedub Transmission - Rearend 2 12-26-2009 08:06 PM
GM HEI Module Keeps Burning Out ripvanhalen Electrical 6 09-24-2007 11:28 PM
Procomp HEI and MSD module no go! Jmark Engine 5 12-03-2006 07:55 AM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
Mopar Help- module???? WoodsEdge Engine 2 08-13-2003 07:35 PM
