raybestos slotted and drilled rotors - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2007, 06:00 PM
Billvill's Avatar
does anyone else have set of the new raybestos slotted and drilled rotors ? They sound like a frig in synthesizer when you lay on the pads hard . I am very disappointed
I have them on a G20 Chevy van with ssrd pads. I hope it will dissipate but it does not seem to be getting quieter as time goes on.
Old 06-21-2007, 01:51 AM
What year? Did you bend the tabs on the pads tight against the caliper?
Old 07-15-2007, 01:42 PM
Billvill's Avatar
Of coarse I bent the tabs. One problem and Raybestos has yet to reply to my email is that the rotor marked L came out of the R box and vice versa. I installed them with the slots laying back with the wheel rotation. I may switch them to see if it makes a difference.
I guess I am disappointed in the tech line for not responding to two emails.
Old 07-15-2007, 03:25 PM
Do the rotors have directional vanes or straight vanes?
The slots should go "forward" (i.e. at the top of the the rotor the vane should start at the ID and go forward to the OD).
Old 09-14-2007, 06:27 PM
Billvill's Avatar
thanks for the info I think I will change them right to left.
Old 09-14-2007, 08:41 PM
Saw a durango the other day had all 4 crossdrilled/slotted rotors on backwards......should stop better when you turn them around too
Shane
Drilled / Slotted Brake Rotors Advice texastomeh Suspension - Brakes - Steering 9 09-14-2007 06:31 PM
cross drilled rotors on a 67 chevelle m.docken Suspension - Brakes - Steering 13 02-23-2007 07:26 PM
Need help finding dics rotors... bg Suspension - Brakes - Steering 10 05-13-2005 11:47 PM
Rotors... bg Suspension - Brakes - Steering 4 04-25-2005 01:33 PM
cross drilled/slotted rotors chevypunk Suspension - Brakes - Steering 3 08-27-2003 06:45 PM
