Rci Fuel Cell? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2006, 06:32 PM
tombo615's Avatar
Rci Fuel Cell?
Hey guys Im getting ready to break my motor in for the first time this week so I bought some gas and stored it in a vp fuel jug. I go to pour it into the fuel cell before, which is a 16 gallon rci plastic cell, I poured about a gallon in and started checking for leaks. Everything was perfect except for one of the ports coming off of the cell sump. Its a very tiny leak, and when I tried to tighten the male fitting coming off of the sump it just spins. Has this happened to anyone before? How can i fix it?
Old 12-05-2006, 06:45 PM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
You'll have to drain the cell and remove the foam. You should then be able to reach in (if your hand is small enough) with a wrench and hold the fitting while you tighten the jam nut from the outside. You might as well take the fitting out entirely and make sure the mating surfaces are clean and that the nylon washer that goes under the jam nut is in good shape and then re-assemble.
I have a small 1 gallon fuel cell on my test stand, and had to tighten the fitting also.
Steve
Old 12-05-2006, 06:47 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Tombo615,
There is a nut on the inside of the cell. Open the filler and shine a flashlight in there. If you can't get your hand inside the filler remove the bolts holding the
filler to the cell, this will give you more room.
Bob
Old 12-05-2006, 09:42 PM
tombo615's Avatar
ugh that stinks but i guess i have to do it
thanks for the help guys
Aftermarket EFI ? x007 Engine 61 02-08-2012 11:38 AM
fuel cell cabowabo Hotrodding Basics 3 08-21-2006 10:11 PM
fuel cell foam Vortech 4.3 Engine 6 12-27-2005 08:42 AM
custom floor and fuel cell 16grem72 Interior 1 02-08-2005 03:30 PM
Fuel cell vent Bluepen Engine 1 07-17-2003 06:23 AM
