rcl polly prime Vs featherfill - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2013, 01:25 AM
working on a custom harley with a stock tank that had been stretched and a taildragger fender. Both of which are very rough. looking to pick up another gallon of polly and have always used PCL. WHat are your thoughs or how does featherfill compare ?
Old 01-08-2013, 06:04 AM
Pick up some Duratec, one of the best poly primers I have ever used and I have used quite a few. Sands so easy you won't beleive it.
Old 01-08-2013, 08:49 AM
put up or shut up
PLC is not nearly as thick as featherfill and featherfill is not as thick as Slicksand. PLC in my opinion sands better than both. With Featherfill you sometimes have to wait longer than expected to sand. You'll think it's ready but you put a block on it and it's not. Don't have that with PLC. With PLC you'll need a scale to mix.
So you got two completely different types of hardeners. Featherfill will help more imperfections.
Old 01-08-2013, 10:42 AM
S10xGN's Avatar
Gotta love a turbo!
What exactly is "PLC"? Is that a name brand or an abbreviation for the type it is?
Russ
First time spraying PPG DP50 and Featherfill G2. Advice needed. Riot Racing Body - Exterior 19 02-24-2012 09:02 PM
Need Some Advice Before Shooting FeatherFill G2!! texastomeh Body - Exterior 27 05-24-2011 09:41 AM
featherfill with a 1.8 tip? americanLT1 Body - Exterior 2 06-25-2009 08:47 PM
Polly locking nuts Tonythefish General Rodding Tech 7 03-10-2007 12:32 AM
FeatherFill G2 shoddy_f-body Body - Exterior 20 08-10-2005 08:11 AM
