Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Re: '68 Mustang Rear End
Old 03-20-2013, 08:27 AM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
The Explorer has a lot of pinion offset that would need to be corrected by shortening one axle tube and axle. It will also need the correct spring perches in the correct loaction. You will have to change the pinion flange to a yoke or modify the drive shaft to work with the flange.
The 8 inch is a pretty good rear end and could hold up to a mild 351 with an automatic.
