Re: '68 Mustang Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2013, 08:17 AM
Mac88's Avatar
"Drive It Until It Breaks"
Working on a 68 Mustang Coupe. My plan is to pull the 302 out and replace it with a 351W / C4 combo. The question I have is in reference to the 8 rearend. Will the 8.8 out of an Explorer bolt right in or will there be some medications needed. I'm trying to avoid having to get into shortening a rearend and all that. I know where I can get a 9 that will bolt right in, but I already have an old 8.8 out of an Explorer that would save me a couple of dollars if I could use it instead of buying the 9.
Old 03-20-2013, 09:27 AM
big gear head's Avatar
High Performance Rear Ends
The Explorer has a lot of pinion offset that would need to be corrected by shortening one axle tube and axle. It will also need the correct spring perches in the correct loaction. You will have to change the pinion flange to a yoke or modify the drive shaft to work with the flange.
The 8 inch is a pretty good rear end and could hold up to a mild 351 with an automatic.
Old 03-20-2013, 11:54 AM
prostreet6t9's Avatar
Differential/Driveline
I'd do the 8" also.. Plenty of Aftermarket support and it will hold up fine.
mustang rear end bgraham Transmission - Rearend 4 06-29-2011 12:58 PM
67 Mustang rear end mtgmustang Transmission - Rearend 4 03-14-2007 07:19 AM
66 mustang rear end gun70runner Transmission - Rearend 1 02-18-2006 06:53 PM
mustang rear end Stangman196700 Transmission - Rearend 0 02-16-2004 04:53 PM
mustang rear end,,help chrislana Transmission - Rearend 1 06-07-2003 09:59 PM
