Re-adding gasoline to an old tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2013, 10:47 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Any special precautions to watch out for before I add gasoline to the tank prior to engine/cam break in? Water, rust, gunk?
There was about a half tank of gasoline in the tank for a decade or so. The engine is rebuilt and ready to break in now. I used a manual pump and sucked all the gas that would come out through the hard fuel line that goes to the fuel pump. I am sure there is still liquid at the bottom of the tank though. Should I add SeaFoam or some other additive to offset any water in there? Its a hydraulic cam, so I do want this thing to fire up and run right away for break in.
Old 04-16-2013, 12:27 PM
Faith - Respect - Trust
Get the tank steamed...any rad shop should be able to help you out with that. Whatever they charge, it's cheap insurance when you consider the cost of an engine. Seeing the tank has been sitting for a while, get them to pressure test it as well. Don't need any of that $5 a gallon fuel leak out of a clean but porous tank
Ray
Old 04-16-2013, 02:07 PM
Old gas
I would also make sure to either replace the fuel line or make sure it is cleaned out of old gas/gunk. With cleaning the tank and line out you will know for sure your not going to suk anything into the carb. If it gets that far.
Old 04-16-2013, 02:23 PM
sedanbob's Avatar
Gas sitting around that long can leave an awful lot of gunk in the bottom of your tank. Today's gas with ethanol will dissolve a lot of that, and it will clog your fuel filter if you're lucky, or end up in your carb if you're not.
Adding compressor storage tank HVAC Phil Garage - Tools 3 08-01-2011 08:21 PM
Adding Overflow Tank to Cooling System JohnTN General Rodding Tech 4 06-15-2010 06:56 PM
adding on a extra compressor tank ikeaguirre1414 Garage - Tools 7 09-13-2006 06:34 PM
Adding gas tank outlets syborg3D General Rodding Tech 1 02-03-2005 08:49 AM
Adding 2nd air tank to compressor cboy Garage - Tools 7 10-26-2004 11:17 PM
