Re arc springs 2" lower, or use 1" springs and blocks? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 11:45 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
I have been talking to a few local spring comapnies. One of the latest guys, said that I should only lower the springs 1", if I go 2" it will take too much arc out of the leafs.
After the 1" loering springs he said to add the lowering block, to get the final ride height
Good advice, or not?
Old 10-22-2005, 12:07 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
What kind of car?
Old 10-22-2005, 03:27 PM
Ripped's Avatar
67 mustang
Old 10-23-2005, 12:39 PM
xntrik's Avatar
I do Fairlanes, Falcons, Mustangs. My personal car is 63 Fairlane.
I wouldn't waste my time $$$ dearching springs.
1) The best solution is reverse eye springs. The front eye is centered to the spring, and the rear eye is reversed. Readily available from Mustang suppliers.
2) Cheapest = Lowering blocks increase the leverage on the springs that will increase wheel hop. You should clamp the front spring leaves to reduce the hop. Make your clamps out of 1/2 steel and use 3/8 inch grade 8 bolts. Actually, just clamp the leaves on ANY FORD.
3) You can safely use a rear shackle that is one to 1 1/2 inch max shorter. That will give you about half that much drop at the wheel well. Make them from the long lift shackles (70s) cut off excess, weld the bolt heads into the shackles)
Always use urethane bushings at each end. They really help the wheel hop. I noticed no ride/noise difference.
Also if you have a wheel hop problem and your car is equipped with rubber spring isolators where the spring u-bolts to the leaf, eliminate that. That raises your car about 3/4 inch, but the height can be adjusted as explained.
My car has custom built springs, no blocks or isolators, and then had to do # 3 to get my desired height, and still clamped my leaves. (I hate the look of traction bars hanging down)
www.readershotrods.com drag cars/georges
Old 10-23-2005, 01:52 PM
Ripped's Avatar
Thanks, good tips
Rear leaf springs, lowring blocks, and air bags? Cowtown Punk Suspension - Brakes - Steering 2 07-06-2004 06:33 PM
