Re-arcing leaf springs in the San Fernando Valley? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2011, 08:31 AM
Groucho's Avatar
anyone still do it? Thanks
Old 12-19-2011, 05:52 PM
boatbob2
Springs.....
Hi,re-arch the springs yourself,BEFORE you start,draw the curve of the spring on the floor with chalk,i used 2 pieces of 4 inch thick wall tubing ,placed them about 12 inches apart,put spring over the tubing,smack it in the middle with a sledge hammer,smack it hard,nice if you have someone to hold both ends of springs while you beat on it,(use gloves)after hitting it,put it on the curve you drew on the floor,not curved enough? smack it about 12 inches left and right of center.check on chalk drawing after EVERY hit.have fun,YOU buy the beer when the job is finished.That spring is TOUGH,youre not going to hurt it,....
Old 12-19-2011, 06:20 PM
Groucho's Avatar
I found a place very close by (gotta love SoCal) that did it for $40 and it was back to me in 2 hours. I'll keep your tip for next time, thanks
Old 12-19-2011, 07:47 PM
Wiki Edits: 27
HF pipe bender.
Reverse Eye bend. I did the main leaf and turned the frown into a smile. I used my Harbor Freight Pipe bender and NO die on the jack. I chalk marked the spring every inch . I jacked until I saw the end of the spring move a little. release pressure . move over and jack again. I kept working it until it matched the chalk marked pattern on the floor. It dropped the speedster about an inch.
Old 12-21-2011, 12:19 AM
tristanaddis's Avatar
New Member
I tried re-arcing the springs on my own but unfortunately didn't succeeded in doing so...Now I need to know where should I move to get my springs re-arch..
compression spring
leaf springs goobbl Transmission - Rearend 0 05-08-2008 08:06 PM
leaf springs 49dream Suspension - Brakes - Steering 5 01-25-2007 09:05 PM
Valley Springs Custom Differentials 3100 Special Transmission - Rearend 0 12-17-2005 03:33 PM
leaf springs johnnymopar Suspension - Brakes - Steering 1 05-28-2003 05:35 PM
leaf springs onehotchev Suspension - Brakes - Steering 3 03-20-2003 03:43 PM
