Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Re: Carb Cleaning
Old 03-21-2014, 02:16 PM
oldbogie oldbogie is offline
Originally Posted by Mac88 View Post
I'm disassembling a Ford 1100 carb for rebuild. I want to let it soak in carb cleaner for a couple of hours, but I'm not sure whether or not that would damage the power assembly. I'm not sure what rubber pieces are inside the power assembly but I've been told it shouldn't be removed. Will it be safe to soak the carb for a couple of hours with the power assembly?
Yes it would, carb cleaner depending upon type would either dissolve the non metal parts or cause them to expand from which they do not contract when removed. either way these rubber or plastic parts are ruined.
Bogie
