Re-drill bolt pattern? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2004, 05:48 PM
Rhansen's Avatar
Footbraker
I have a set of 15x10 steel wheels that I am considering re-drilling the bolt pattern from 5x5 to 5x4 3/4. I imagine I'll need some kind of template/bit guide to do this, if it's not perfect then it will have a bad vibration. Anyone ever tried this before?
Old 05-02-2004, 06:51 PM
poncho62's Avatar
Wiki Edits: 5
I made a set of 4 1/2 bolt pattern to 4 3/4 bolt pattern. These were aluminum wheels and I lengthened the holes with a dremel tool and hand file. It's like a "unilug" wheel now. worked OK, but was quite a bit of work.
It would be near impossible with steel wheels that need a tapered lug nut.
Old 05-03-2004, 12:23 AM
4 Jaw Chuck's Avatar
Steel wheels have a reverse flange under the tapered seat of the nut, do not redrill them unless you re-punch in this safety feature using a large press and associated dies. Most people don't have access to the equipment that will allow you to do this so it is generally a big no-no.
— Han Solo
Old 05-03-2004, 09:19 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Right, It's hard to keep your nuts tight if you don't.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 05-03-2004, 05:11 PM
Rhansen's Avatar
Footbraker
What about using a grinder to make the "reverse flange"?
My idea was to use my brake drums (which have both 5x5 and 5x4 3/4 pattern) as a template. I only want the wheels to run some 27x10 slicks at the dragstrip, not for street use.
Old 05-03-2004, 06:30 PM
troy-curt's Avatar
Grinding will make it to weak around the stud.
Look at an org steel wheel, you could use a punch to counter sink them from the rear. A press would be better.
Troy
Old 05-03-2004, 11:19 PM
poncho62's Avatar
Wiki Edits: 5
Get you axles redrilled to 4 3/4, if you have the drums that will fit them..........less work and safer.
Old 05-04-2004, 12:40 PM
Rhansen's Avatar
Footbraker
my axles are 5x4 3/4, I had the drums re-drilled to fit the axles and (street tire) wheels
Old 05-08-2004, 02:12 PM
Rhansen's Avatar
Footbraker
I went ahead and bought some new wheels (Cragar Nomad I) since re-drilling sounds like it may be unsafe (FYI Jegs was the only place that I could find the correct wheel, some places told me that they don't have 15x10 steel wheels anymore)
Guess I will try to sell the other wheels
Old 05-08-2004, 02:38 PM
WoodsEdge's Avatar
Smartest thing you could do!
Jack
