Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Re-filling coolant
Old 03-03-2012, 08:24 PM
loafing1 loafing1 is online now
>By filling the rad you fill the block also .
Awesome - thank you! That's what I needed to know.
>Start your motor and check coolant with motor running ' and the rad cap removed .
Rad will be cold of course when you first start the motor so there is no chance of getting burned ..and once the thermostat opens you will see the coolant circulating in the rad .
If it appears low add some more coolant .
When rad is full put on the cap and put some coolant in the reservoir
That's exactly the way I as going to burp/assure it was filled up right.
Thanks much!
