To Re-mount or Not to Re-mount? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 05:32 PM
fiftysix Chevy's Avatar
I know lame title, but I would like opinions about front vs. side engine mounts for a 56 Chevy two door sedan. My car has a mild 350 engine, and I was going to upgrade the rubber front mounts to polyurethane. Is this sufficient or do I need to install side mounts (the block has provisions for both). My seamless frame is in excellent condition (CA car) and I'd rather not modify the frame unless I am convinced that the conversion to side mounts is a must.
Thanks,
Jim
Old 01-27-2006, 06:23 PM
Marcel
Last journal entry: Choo-choo town
side or front mounts
I can only said that I've need broke a front mount in the 55, 56,or 57 chevy.
but there is more motor vibration with them. If I wasn't going to jerk it around and wanted smooth ride, I'd go with the side mounts. You can make a nice job of the welding on the frame nice and neat. Flip a coin?
Mount TWOPLYM Transmission - Rearend 1 07-08-2005 04:38 AM
Pontiac 3400 serpentine belt/motor mount problem ChevelleSS_LS6 Engine 3 06-15-2005 03:15 PM
oil filter mount bypass valve? fireforsin Engine 3 10-14-2004 04:18 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
front sway bar mount location fire power Suspension - Brakes - Steering 2 05-17-2003 07:10 AM
