Re-named project - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 04-21-2009, 10:12 AM
Last journal entry: All paint hiccups fixed!
Re-named project
I actually started this project as "the '49 chevy truck's journal"
However, I realized that this was going to be a special project for lots of reasons. The first is that we are going to try and complete the rebuild in one month. It'll probably be more like six weeks, BUT, we're going to give it a shot. Hence the name of the project. The other thing is that we are going to complete the rebuild for less than $8,000. Now, you have to understand that I inherited the 1949 chevy 3100 pickup from a lifelong friend that passed in January. He had been working on a frame up restoration and had gotten as far as the frame. So the suspension and chassis have all been rebuilt, painted, and ready to roll. So I don't have the expense of purchasing the starter vehicle, and I don't have to spend any money on the suspension or chassis. At the same time, we are changing the engine, transmission, rear end, drive shaft, and steering. We found a conversion kit that will allow us to use the stock front end, and convert it to power steering. It'll need a new steering column and some of the steering linkage will be replaced, but most of the stock steering will be kept. Also, the interior is only going to get a quick going over, meaning, paint, new seat cover, and reconditioning of the dash. I'll get one of those molded carpet things made to fit that cab and leave it at that. At some point in the future I'll have the interior of the cab professionally upholstered and carpeted. But for now, that isn't a part of the rebuild.
What we will do, as mentioned we're changing over to a chevy 350 small block v8, 350 turbo tranny, ford 9" rear end, and modified drive line. We're going to lower the truck a bit, and give it a new paint job. The paint is another thing I don't have to spend any money on. I have some paint left over from the last project that will work nicely on this one. It's white pearl, three stage paint, and we're going to add some yellow and orange to the white base to give it a mild tangerine coloring under the pearl. I'm going to attempt to air brush flames on the hood and fenders. We're not going to get anything chromed, instead anything that would normally get chromed, stainless steel on the dash, stainless steel trim around the sun visor, hood emblem, etc. is going to get painted black and then pearled on top of that. It's a great look and will suffice nicely in place of chrome and will save literally hundreds of dollars. This truck is going to be a daily driver, so I'm not so interested in creating something that needs to be towed to car shows, in fact this is the truck I intend to use to tow the '39 Plymouth to car shows in an attempt to sell it.
We've got to finish the '39 Plymouth first (ezinoregon's journal) and then we'll start on the chevy. So check back here somewhere around the middle of May and see if we can make the one month deadline!
Old 04-22-2009, 04:09 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to the Hotrodders Bulletin Board.
Old 04-22-2009, 08:54 AM
ezinoregon's Avatar
Last journal entry: One Last Shot
thanks
Thanks, I've actually been using this site for a couple of years now. This is a great site and I've found help, advice, and great comradery.
I'm Bored...How About A 1967 Pontiac GTO Project ??? izzymiddleton Hotrodders' Lounge 9 03-07-2009 10:26 PM
New Member 1st Project 86 Cutlass 86cutty Introduce Yourself 4 03-27-2008 04:00 PM
Project planning 580Z Hotrodding Basics 5 04-27-2005 03:20 PM
The SN65 Project Car - graphic design SN65 Body - Exterior 0 03-21-2005 10:22 AM
