RE: new longblock in 1990 454 Mercruiser fresh water cooled gas 330hp 7.4l
ok, here goes-I confess I'm a boater with a Sea Ray 350 Sundancer 40' LOA with twin Mercruisers. But I'm having a real problem that maybe you guys who really know engines can help me with anyway since I'm getting nowhere with fellow boaters!
I went ahead and had new reman longblocks installed last year, did the 10 hour break-in and had them adjusted and checked. Now with 16 hours on them one of the holes in the port engine is not getting oil to the push rod (only a little spurt now and then). Had a new push rod assembly and lifter installed and still doesn't work. No one can figure out why. I suppose it could be something like an obstruction or a lifter that was not adjusted properly to begin with? |
Welcome to the site,
We have several boaters on here post in the engine section or check out our lounge. Cole |
Possible causes:
Exccessive distributor body to engine block distributor hole clearance. Blocked lifter oil gallery. Excessive lifter bore clearance, another faulty lifter. (after market flat tappet lifters seem to be getting crappier since OEM's no longer use them in OEM engines.) OEM's have the volume buying clout to insist on a certain quality on these critical OEM parts or make their own in house. Many of the replacements are made off shore now. Many of the off the shelf replacement and popular high volume high perf cams that are sold in volume are also made offshore now. EG: Comp cams sells more XE cams than it could ever hope to produce in house. Someone is makeing all these XE 268 cams and most likely at the cheapest cost. |
many thanks
Thanks guys for the suggestions. I'm taking them to my yard owner and see where we get with this problem.
I'd also suggest you see what the oil pressure is under varying conditions/RPM to see if there's a problem w/how much pressure is being supplied. And for peace of mind. If you have an adjustable valve train (net lash started in 1991, I believe), you can try using a different preload setting. Sometimes increasing the preload is all that's needed to restore flow. It could possibly have too much preload, for that matter. Has the oil flow been checked w/the engine at 2000- up RPM to see if the flow increases w/RPM? If you have a "net lash" valve train, the preload isn't adjustable. If the preload is incorrect, you will need either different length push rods or convert the valve train to an adjustable set-up. I would also check to see what the geometry looked like. This is adjusted w/different length p-rods, like the preload on a net lash system. If the valve train's adjustable, the preload doesn't require a p-rod length change, but to adjust the geometry, the p-rod is still changed. Last edited by cobalt327; 05-17-2010 at 07:14 AM. |
