re tow truck torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2013, 09:41 AM
m/w m/w is offline
Z 55 Camaro
Location: Guernsey Sk Canada the greatest country in the world
re tow truck torque
A late merry christmas & happy new year to you all . Well we finally got the tow truck engine home . A few hang ups 1) the 472 turned out to be 500 which was no biggy .The dyno #'s were very impressive , 585ft lbs at 3000 (cause thats as low as the dyno would go ) and 430 hp at 4000 rpm . I,m not 110 % sure of the numbers but these stick in my head . Now the kid is having second thoughts ie some manner of street car .hummm
Old 01-08-2013, 10:15 AM
vinniekq2's Avatar
whats the question? and what kind of engine is it?
Old 01-08-2013, 11:21 AM
327NUT's Avatar
Well Vinnie it's a Cadillac.........585 trq. sounds a little high for a stock engine....is it? Mine is pretty well "built" but still retains a gas friendly 8.7:1 comp. ratio. It did 535 trq. @4300 and 466 hp @5000.
The trq. came on VERY strong right off idle and this dyno doesn't read below 3000 also but I was at 489 trq. there. For more info on the Cadillac performance builds go to www.cadillacpower.com.... lots of good info on the forum.
ID:	70380   Click image for larger version
ID:	70381   Click image for larger version
Old 01-08-2013, 11:33 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
From what I gathered,the stock Caddy is fine,but once you start playing around with aftermarket overheads it gets expensive in a hurry.
The Following User Says Thank You to 1Gary For This Useful Post:
TMF Lindbeck (01-08-2013)
Old 01-08-2013, 11:47 AM
vinniekq2's Avatar
That sounds like an engine I would want in an old 50s truck.If it pulls to 5k then any cool sled would also be a good home for it.
where do you plan to use that engine? I want to see the finished product
Old 01-08-2013, 02:54 PM
techinspector1's Avatar
Wiki Edits: 326
Both of us
Old 01-08-2013, 03:10 PM
Wiki Edits: 326
Could you bless us with a list of parts that you used? There's a whole year missing in the build of this motor and we have no idea what you used.
Old 01-08-2013, 09:39 PM
m/w m/w is offline
Z 55 Camaro
I will go to the shop and try to find info in the kids parts boxes on the build , don't want to list anything that isn't in the build . Later bake
tow truck torque m/w Engine 23 01-07-2012 04:59 PM
Want a challenge? Cheap Tow truck...... Rob Keller Hotrodders' Lounge 4 02-25-2009 02:03 PM
Elligible Tow Truck Models... Dill-the 65ImpSS Hotrodding Basics 4 02-28-2007 10:15 AM
tow truck takes a hike bullheimer Hotrodders' Lounge 2 01-28-2006 10:24 AM
1940 tow truck-should i keep it or what? bullheimer General Rodding Tech 32 11-08-2005 12:27 AM
