Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Re-use sway bar?
Old 12-05-2012, 02:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by cobalt327 View Post
If you're going to lower the Cg, stiffen the chassis (boxing and/or roll cage), or use super sticky tires, then aftermarket bars would be a good addition.
To clarify, bigger sway bars in addition to these mods could help handling, but bigger bars are not needed just because of these mods.
Actually it could be argued an unmodified car will be helped more than a modified car by using them.
In your case I'd put it back w/new bushings and see if that's enough. Adding a larger set of OEM bars will only need a different set of bushings and possibly different bushing brackets if the bar on it now is a lot smaller than the replacement. I ran into this on F-body cars.
