Reading my spark plugs. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2005, 08:17 AM
I took out all the 8 spark plugs to clean them and ran the motor afterwards for two 60-80 miles runs. This fresh 383 stroker consumes about 1/4 at evey 4-500 miles and my idea was to clean the sparks,wich are champion 12Y with about 1000 miles on them,so I could read them after a precise mileage and use wich was just mild open road 60-75 MPH around 2400-2600 constant RPMs very little if none idling at all,but few bursts to 4500 under accelerations.
I took out and checked only the passengers side and all of those revealed a similar coloration: It is like the sparks would be cut in half having one side pale brown close to white (like a bit hot) and the other side would be dark like too rich; none of the ordinary solid black carbon deposits the oil burning normally leave..just kind of soothy.it'S like there are two separated heat range within the same chamber! I think the oil burning problem is linked to this but can't really figure out how it happens!
Someone can tell me?
thanks,Ronald.
Old 11-26-2005, 08:25 AM
You need to mark the plugs with a sharpie or similar while they are in the engine. Remove the plug wires and mark the top or bottom--which ever is easier for you--(this will be after you have run it for a while) If the soot is on the top of the porcelin, your valve guides are at fault--if its on the bottom, it will be your rings haven't seated yet.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
HELP! spark jumping from wires to the plugs like crazy (long post)!!!!!!!! Blown72Camaro Engine 8 06-22-2004 08:01 PM
Question Performance spark plugs for 98 mustang gt sungho General Rodding Tech 11 08-14-2003 01:00 PM
reading spark plugs abe Engine 8 01-12-2003 08:04 PM
Spark plugs sparking to the side mar10 Electrical 3 07-25-2002 05:51 PM
