Reading ratio on crown gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2005, 01:10 PM
western star's Avatar
I always thought you could read the ratio on the crown by dividing the smaller number in the the larger one. The numbers stamped on the 9" Ford is C3AW-4210-CC-9x35. This one was supposed to be a 3.30 according to guy that has them the other set has C3AW-4210 and that's all the numbers and it's suppose to be 4.11. Does'nt jive at all for these two. Anything I'm missing or is there another way to locate this.
Old 07-17-2005, 01:39 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
gears
If you have a 35 tooth ring gear with a 9 tooth pinion gear. It would be 35/9=3.88. For a general idea of ratio without removing rear end. Put a mark on the drive shaft and wheel. Turn the back wheel 1 full turn and count how many times the drive shaft turns.
Old 07-17-2005, 01:48 PM
aka Duke of URL
The C3AW 4210 C is an engineering stamping no. to identify the actual ring gear. The 9X35 identifies it further as a 9" 35T gear (Not clear as to what the second C represents). There will also be a stamping on the pinion gear. This will further identify the two gears as a set.
If your first ring gear has a 10T pinion gear, you have a 3.50/3.56 ratio. A 9T pinion gear will give you a 3.89. The crossover chart is in the MASTER PARTS CATALOG.
Old 07-17-2005, 06:23 PM
Great and thank you.
whats the gear ratio erockplan9 Transmission - Rearend 4 09-06-2004 11:45 PM
What Gear Ratio 79 Malibu327 Engine 5 04-12-2004 11:30 PM
can you tell my gear ratio? mikeweyman Transmission - Rearend 5 02-24-2004 09:24 PM
Gear ratio for a bonneville? Mike_82 Transmission - Rearend 1 09-04-2003 08:55 PM
Gear ratio Mirror Image Transmission - Rearend 2 02-28-2003 11:00 AM
