Reading spark plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2007, 07:49 AM
elvis 66 chevelle's Avatar
66 Chevelle 406 SBC
Reading spark plugs
I just pulled # 1 plug 400 SBC to read it, my problem is i have to drive down side street 25 MPH and then idle into garage. I don't think i am getting true reading off my plugs. I have aluminium heads, can i check a plug after full throttle run and then shut off car. Do i need to let engine cool off before i put plug back in?? If so do i just snug up plug in stead off tighting and stripping threads??
Thanks
Doug 66 Chevelle 406 SBC
Old 06-05-2007, 07:59 AM
302 Z28's Avatar
Trying to read plugs on a street driven car is a bit of a chore. It is nearly impossible to get an accurate reading due to the varying driving conditions. If you are after a WOT reading that is a little easier. Just make a full throttle pass and shut off the engine and coast to a stop. Put the car in neutral or hold the clutch in as you slow down.
Vince
Old 06-05-2007, 08:32 PM
larryblack's Avatar
Certified Lead Foot
You are coating the plug threads with some anti-sieze when you install them. You do not really need to let the engine cool to reinstall the plug. Unless the mfgr of the heads said to install cold only.
motor wont start spark plugs have oil on them 54chevy22 Engine 3 09-11-2006 06:59 AM
Reading my spark plugs. TVR383 Engine 1 11-26-2005 08:25 AM
Dart iron eagle spark plugs... killerformula Hotrodders' Lounge 10 09-18-2004 11:33 AM
reading spark plugs abe Engine 8 01-12-2003 08:04 PM
Spark plugs sparking to the side mar10 Electrical 3 07-25-2002 05:51 PM
