Reading spark plugs (dry fouling?) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2013, 10:36 AM
Getting ready to sell one of my boats (the one I did the carb/fuel system work on that I was posting in another thread). I figured I'd do a compression check as a courtesy to any potential buyer. I took all of the spark plugs out, and 6 of the 8 were dark in color (like carbon), with no heavy deposits. The other 2 looked to be 'normal'. The plugs don't seem too old, the gaps seem ok. The engine runs fine. We do a lot of idling (while waiting for a skier to get gear on, for instance). Sometimes it seems like the engine idles a little rough, but it clears out fine with no issues.
On an NGK chart, they show a dark plug that looks similar to my 6. They state 'dry fouling'. Not sure why only 6 would show it, as it's an older engine, with all cylinders fed by a 650 Holley.
I'm kinda curious what that dark plug color might mean. Anyone know?
Old 07-25-2013, 11:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The excessive idling will do it, especially if the idle circuit is 'fat'. I wouldn't worry too much about it as long as it cleans up after running. If you're not already doing so, using an extended tip plug may help. You could try a heat range hotter plug, but don't do this if the color is good when you're not idling a lot. A plug chop after a WOT run will help here.
Fouling spark plugs Mertz Engine 5 04-12-2010 04:02 PM
Reading Spark Plugs timhollerbach96 Engine 7 04-08-2009 08:57 AM
Reading spark plugs elvis 66 chevelle Engine 2 06-05-2007 08:32 PM
Reading my spark plugs. TVR383 Engine 1 11-26-2005 08:25 AM
reading spark plugs abe Engine 8 01-12-2003 08:04 PM
