ready to go spray... lots of it. what machine work needed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2011, 03:06 PM
well i have what is to be a built 406 with 586hp (supposedly)... long story short, needs a rebuild. have yet to tear it down to see what failed but im goinf to build for spray. i know forged parts is best with all apr... but what machine work should be done if any for spray?
Old 02-28-2011, 04:14 PM
Landshark928's Avatar
FrankenPorsche
How much is lots of it?
150 or less and you should be good to go. Over 200 and you need to look at cam selection, pulling timing, forged bottom, piston selection and compression, ring design and gap etc.. the specific amount of giggle gas aol determined the answers you get.
Old 02-28-2011, 04:16 PM
F-BIRD'88's Avatar
Yada Yada Yada
There are no other exclusive machine operations to be done that wouldn;t be done to any other motor.
With big nitrous shots the piston to wall clearances may be opened up a bit
and the ring end gaps made larger to account for the additional heat load.
All engines need precision machining. If your engine failed it will need a complete inspection upon teardown. Only then can a estimate of the required work be made up.
Did this motor previously fail while being sprayed with nitrous? or?....
ready to start work again benchracer1 Interior 2 04-16-2010 01:10 AM
Lots of work finally showing progress D9ZZ Body - Exterior 4 09-23-2008 12:19 PM
porting 882s at home,no machine work, rebuild, will it work? what are they capable of Warrant Engine 6 12-27-2005 12:14 AM
Machine work prices and whats needed 59chevyapache Engine 16 02-08-2005 03:11 PM
I'm ready to buy a new spray gun,which one? jdss Body - Exterior 21 11-08-2004 12:22 PM
