Ready to Paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2009, 11:12 AM
Ready to Paint?
I've got my car ready (I think) to finally paint (base + clear coats). My question is:
I had used SlickSand, after the body work, and sanded as required.
I then laid down the 2K primer and wet sanded that with 600 grit.
The car's pretty darned straight at this point, however, there are some areas where, in order to get the panels straight and smooth, I sanded through to the Slick sand.
Can I now paint over the partial SlickSand and 2K primer panels? The car is straight, no doubt about that, but...
What do you think?
Old 08-01-2009, 11:29 AM
mitmaks's Avatar
Last journal entry: Grille
I would seal it first to make sure it won't lift in spots
Old 08-01-2009, 11:39 AM
Oh yes, I forgot about the sealer.
Any sugguestions on what type of sealer to lay over 2K primer?
Old 08-01-2009, 09:08 PM
gto_ron's Avatar
sealer
I always seal my 2K primer with epoxy primer before I shoot the basecoat. You can thin it with 10% reducer for a smoother finish. I got in the habit of doing this when I use to spray lacquer over primer/surfacer. Man, I guess I am getting old.
Ron
Old 08-02-2009, 07:14 AM
Thanks for the suggestion, Ron. It happens to be a GTO that we're working on, by the way.
So, do I need to sand the epoxy before laying down the base coat?
Also, how many coats of base coat do you suggest? I usually spray 2 coats but really want this paint job to look great.
Old 08-03-2009, 01:33 PM
gto_ron's Avatar
sealing 2K
I don't usually have to sand the epoxy primer/sealer, do all your smoothing in the clearcoats. If the epoxy goes on rough for some reason you can sand it lightly with 600 grit. I generally shoot two coats of base; I figure every extra coat beyond that is another opportunity to screw up.
I hope your GTO comes out great, share the pictures with the forum.
Ron
Questions for paint guys - body show messed up my car zbhover Body - Exterior 9 06-25-2009 07:58 PM
Getting ready to paint my vette lot of questions zr1salvage Body - Exterior 17 03-12-2007 05:57 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
ready for paint, need help picking color show me mikeweyman Body - Exterior 3 03-25-2003 02:42 AM
almost ready to paint tumbles Body - Exterior 3 03-18-2003 09:51 PM
