Originally Posted by Old Fool
I believe the Hobbyair can supply 1 man using a hose length of 200 ft.
Every 90 you put in the pvc line shortens that distance fairly fast.
A standard 1" 90 elbow is the equivalent of over 5 feet of straight 1" pipe
Another concern in my mind is air flow through pvc generates static electricity. You might get a dandy of a zap, then again maybe you won't. just a thought.
hello,
thank you for the feedback.
ok, sounds like i should just use the hose / setup as is without modification.
i was at another person's garage last night. he also uses a hobbyair system. he has had his system for some time (years).
i asked him if he ever considered doing what i proposed / asked.
he said, "why bother - the hose is not that big of deal to move around, once you get used to it."
he just takes his unit and sets it outside when he works.
i believe i will just keep things simple and use the unit as it was intended.
thank you,
mark
