Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ready to be set straight!
Old 12-06-2012, 07:00 PM
guzzidude's Avatar
guzzidude guzzidude is offline
Happy to finally join after reading the threads on here for so long.
Ok,
After reading many threads on here and other forums, I decided to post my options for my build and hope to gain some answers or atleast opinions. I am ready to get bashed for atleast one option. I'm sure it will be eviddent. This is not my first build, but my first with these options/dilemmas.
I am back from messing with British cars and picked up a 47 Aerosedan. It is in the same build stage as I received it 2 mos ago. The body is in solid shape with minimal body work and the frame is really clean/solid. It is missing pretty much all of the trim, door handles, bumpers, , front splash pan, hood baffle/latch, and the entire interior except the dash/steering, which is in tact. The grill is there but was stripped/glazed. The window mech. parts are there as well as a few others. Basically all of the meat is there. It is equipped with a 54 belair 235(Y)originally powerglide motor) and the original 3speed/torquetube setup. It would probably run with a little attention, it's very clean in and out. Not sure if the PO used the orig 219 flywheel/starter.
I have decided that yes it does have a good solid body, but most of the original shiny parts are gone, so why not make it a nice rod/mod driver. I have 7mos. old son now, so I would like to it to be functional and safe as well.
My initial thoughts suspension wise were for a Mustang II front end, new column, and posey rear susp. with a 10 bolt rear. Engine wise I would like to build another 350 with th350 or t5. But being a frugal father now, it is tougher for me to afford this type of package in the quick fashion I like to work on things. Slow down?
The next thought was to rebuild and lower the stock suspension. The rebuild lits for these front ends is a little money as well as the rear susp. Steering and brakes not sure. Engine wise, I would still like to do a 350 build, so there's the cost of setting that up as well. Or I could keep the 235, get an adapter for a th350/700 and throw in a rear.
The third option, which will be frowned upon for sure, but gives me a lot of parts is a frame swap with a 73-77 Monte or Grand Prix. I thought with this I get an updated suspension/steering/brakes, ease of parts at local retailers, a whole drivetrain, interior seats, and electrical. All this stuff for a pretty reasonable price considering the other options. I know there is a lot of work involved with a swap and it doesn't discourage me at all.
I am know most of you have answered this question to many others. I wrote this because most of the other guys asking these questions had different cars or different circumstances. With the car missing all the chrome I cannot afford, I would like a good looking cruiser. I would just like to find which would be considered best for my situation and where to aquire said parts reasonably.
Thanks in advance,
Matt
ID:	69621   Click image for larger version
