ready for spring and got some questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2007, 04:11 PM
hey guys i got some questions about my motor. its a 355 chevy motor-cola crankshaft-manley rods-wiseco pistons-1.94 gm heads-elgin pro stock cam specs are 230-230@50-480 gross lift rpm power good from 3000-6500-victor jr intake with 2 inch spacer-holley 650 cfm vac.sec carb-proform geardrive-tci street ratteler damper. well im ready to get this car going this spring after buying it from my uncle 2 years ago. but im kinda discouraged about my compression and my rings on the pistons. this car hasnt seen but maybe 5 miles street time since the motor was built 4 maybe 5 years ago. my uncle would start it up maybe 3 or 4 times a month before i bought it. well since then i have i bought the car and did bodywork and suspension work to it plus so minor bolt-ons. i ran across this 750 hp double pumper carb and put it on and it was way to big so i went to a 600 or 650 barry grant carb nothing but problems with both carbs so i switched back to the 650 holley and eveything is fine. the motor revs easy idles awesome and sounds healthy... but its smoking alot out of the drivers side more than the passenger side... it smells really rich and my oil smells of gas really bad so much that its thin. i know i need to change oil and the plugs. i guess my question is how can i tell if my rings are toast or not??? i did a compression check last night and i got 130 psi in evey cylinder is that good or bad ??? these 194 heads im running are 76 cc chambers. or is this just a case that i need to drive the car and until then not let it sit there and just idle all the time? SORRY FOR LONG THREAD..... THANKS CURTIS
Old 03-09-2007, 04:19 PM
techinspector1's Avatar
Wiki Edits: 326
130 would be fine for a stock '72 Buick.
I don't mean for that to sound like a smart-*** answer either, that's just the naked truth of it. Change the oil and drive it for a while, then re-test. Do your compression test with the motor hot, all plugs removed and the primary throttle blades wired open. Oh yeah, and disable the coil.
My best thinkin' would be that you've overcammed the motor for the available static compression ratio.
Old 03-09-2007, 06:27 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Just starting an engine a few times a month will not break it in. Go out and get some miles on it then retest.
If you just run an engine like this you take the chance of washing down the cylinders with fuel and messing up the proper break-in cycle.
Get out to a deserted country road, accelerate hard from 30 - 60 then let off back to 30...do this a bunch...it will help set the rings.
Old 03-10-2007, 07:27 PM
motor
i have a hughes turbo 350 tranny and a hughes 3500 converter 3.73 richmond gears.
