Ready to start on the Plymouth...PICS - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 07:03 PM
Hey Gang...
After much hassle with the construction and completion of my shop, I am FINALLY ready to start on my 1941 Plymouth Hot Rod project. As I stated before in other post, I am going for look that a guy in the 60's would have done with the car.
I am going with a 275hp Mopar 273 with A833 4 speed with Ford 9" rear, fat wide white wall radials with full moon racing disks, NOISY exhaust...etc...
Anyhoo, just wanted to say thanks for all the guys who answered my questions and shared their wisdom, which can only be obtained by the building of these great cars. Rest assurred, that I will be back on here looking for help again!
This is a great community!
Here are some before pics...
And here's the shop...
Ty
Old 02-01-2009, 07:17 PM
31 five window
Last journal entry: grill and rear end
Way cool. I like the direction you are going also. Good Luck and keep the pics coming.
Old 04-23-2009, 08:32 PM
UPDATE on project..more Pics!
Hey Gang....
Things are moving along with the 60's HotRod 41 Plymouth. I have been scrounging parts, ebay-ing like a madmad, and fabricating all the little bits that don't exist.
SO here's some pics!
Here's a pic of the removal of the boat anchor motor. It was surprising how BIG this motor was. And to think I was concerned whether or not a V8 would fit...I could probably have been able to fit a big block in there!
This is the tranny support/crossmember that I fabbed up. The side tabs are 1/4" steel and the 1" square tube has 2/8" walls...I was doing chin ups on it to check for strength.
Here's a pic of the 273ci with a purdy new paint job. I am using original 340 exhaust manifolds, 4 barrel cast iron intake, 273 Charger air cleaner.
Here's the front end after I fabbed up and installed the motor mounts, added the fabbed bracket for the clutch cylinder (next to brake master), and painted the bay. The mounts are poly bushings with steel inserts that are welded onto brackets that I made of 1/4" steel plate. A 7/16 bolt goes through the motors factory motor mount tabs and through the mounts.
Here;s a pic from tonight after I cleaned the place up a bit. As you can see, the 73 Chevelle is home now, so I am having to jockey the cars around to used the hoist. On that topic, the hoist has been the greatest tool that I have out there. Makes pulling an engine pretty easy!
Tommorow's task is actually dropping the motor/trans into the bay...AND LEAVING IT THERE! No more fitting, and adjusting, and messing around! I'll keep the pics coming.
Oh..here's a bit of Musclecar porn for all you other pistonheads! 1973 Chevelle with 475hp 383ci Stroker motor. Alum heads/intake, 11:1 forged pistons, full roller motor...4.10 gears, built trans, etc...
http://smg.photobucket.com/albums/v4...=HotRod074.flv
http://smg.photobucket.com/albums/v4...=HotRod073.flv
Ty
Old 04-23-2009, 09:07 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
that looks real nice and i like the shop too it looks nice and cozy!lol
Old 07-04-2009, 04:37 PM
IT LIVES! Plymouth now running!
Hey Gang...
Here's an update on the 41 Plymouth retro-rod project.
Me and the little lady got the last bit of work done to get the engine put together and running. Here's a pic and video. Still have lots to do, but I am on the way. I need to get the car done by mid-August for Mopar Fest...I already registered to go!
More pics to come as I move along...
Old 07-04-2009, 08:10 PM
Wiki Edits: 49
Very nicely done so far. Its nice to see someone put a Mopar in a Mopar instead of a SBC.
Old 07-04-2009, 08:54 PM
life is a temporary assignment
It's coming along nicely...Centerline.. I knew you would say something like that..LOL
Old 07-05-2009, 12:44 AM
My thoughts exactly! And not only did I use a Mopar engine, but I used a hard-to-find early one instead of a run-of-the-mill 318 out of a pickup. My 273 is a 1965 from a Barracuda (factory 4 barrel). Sounds nasty...solid lifter motor too, so she'll wind out nicely.
Tommorow I am going to sandblast and paint the new rear axle and rims.
Ty
Old 07-05-2009, 08:58 AM
Wiki Edits: 49
The 273 is a great little engine. Had one in my '64 Barracuda my senior year in high school. It was only three years old then and it even had a push button torqueflight.
Old 08-24-2009, 12:45 AM
Buy usa d job u savmaybyourown
nice
breathtaking. really nice piece of work. I love chrysler. The heart shaped grill sets these apart from the standard fiberglassed up willys. The willys look good too but theyve become run of the mill. Im all for the chrysler products that arent mitsubishi driven. I hope fiat doesnt ruin the last ten years of rebuilding a reputation.
Old 08-26-2009, 05:48 AM
deadbodyman's Avatar
Wiki Edits: 11
DANG Speedie you took the words right out of my mou----finger....I got two 48 ply biz coupes and 35 yrs in the P&B biz...if I can help with anything ,feel free to ask
Old 08-26-2009, 05:53 AM
Wiki Edits: 11
T...I need that carb from the flathead......PM me we can make trade....
Name:	100_5229 (Small).jpg
Old 08-26-2009, 06:24 AM
Hey...I wish you had emailed me in the fall...when I gave the whole engine away! I had JUST completely rebuilt the carb, and it was working great. Ah well...
Ty
Old 08-26-2009, 08:25 AM
help
#1 Im looking for the rear window trim on a 1941 sedan.
#2 I just got tin man motor mounts in and am looking for advice on installation.
#3 I have an 8 3/4 rear mopar axle im trying to figure out what the electrical plug is for in it. I pulled it from an 89 shelby dakota 318.
#4 hooking up ladder bars on my old x member frame.
I set my 904 in the car with much grief but of course I will never have to pull it out chrysler doesnt even recomend changing the fluids its so bulletproof. I will be chucking in a 488 hp 360 la from a wrecked 71 dart swinger. 11.5-1 with a lunati. pro form 750 carb, and I just got this giant msd ignition in. barely fit behind the dash. I had to beat it in with 10 lb hammer ----- just kidding im so freakin excited who needs viagra when you have a rumbling mopar. maiden voyage is set for October 5th my birthday.
Old 08-26-2009, 01:57 PM
Wiki Edits: 11
AWE CRAPPER !!! might have winder..motor mounts ez...when in doubt,leave it out...ladder bars ez too.sounds very cool ...I mean hot. Pm me ..you call ,we talk...
Need help with a stubborn 4.3L V6 that won't start Mad Maggot Engine 14 10-06-2011 11:48 PM
Mustang Club of America invades Canada meet pics dude11 Hotrodders' Lounge 2 08-04-2008 11:08 AM
Some pics from the Jalopy Showdown '08 monstergarage87 Hotrodders' Lounge 3 05-18-2008 06:16 PM
head gasket replacement now car won't start jesse01 Engine 10 04-28-2007 05:53 AM
Welding Question?? Scratch Start?? 1931 steve Garage - Tools 3 01-05-2006 06:52 PM
