Ready to turn the key - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-03-2007, 05:31 AM
302 Z28's Avatar
Mike, I have considered using the lower hinge as a method of running the wires and that is probably what I will do, just have to fabricate some kind of cover for the wires. The contact type would be a PIA as I would have to cut the mounting hole through the 1/4" thick hinge mounting plate in the "B" pillar.
Brian, I have looked at all the commercially available wire chases and none will work with the geometry of the 34 Ford's offset hinge design, thanks.
Vince
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
My Hiboy Needs Turn Signal System Higirl Hotrodding Basics 15 09-01-2006 01:19 PM
turn signal shortage texasfinest1 Electrical 2 09-16-2004 02:13 PM
crank key fitment blndweasel Engine 4 07-09-2004 08:58 AM
key stuck in ignition WeberVette Electrical 3 12-10-2003 01:01 PM
