Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ready to turn the key
Old 01-01-2007, 01:36 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
If your real nervous about power...
Get 2 ~ 12 Volt Lantern Battery's in Parallel, and use them for your FIRST low Voltage testing...(Don't try and run headlamps ect..) If it all checks, you should be good to go with a standard Automotive battery.
If any shorts exsist..There is not enough current with lantern battery's to do any harness damage.
Best "O" Luck!
Doc
