Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ready to turn the key
Old 01-02-2007, 09:39 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
Try an accordion style Rubber Boot..(you can find in about any boneyard in a late model car..) It will fit between the A post and the Door frame, and when closed, will "fold" onto itself.
Be sure you put a rubber coated Adel clamp on the A post side and another at the inside door frame for stress relief, and be sure it is at maximum "extend" (door open) ..
That should work fine for power windows and locks as needed for the doors. Be sure the "boot has a "snug fit when you cut the holes, add pliobond glue to assist the boot.
Doc
