Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - this is a real head scratcher...any logical explanation?
Old 07-29-2013, 07:20 PM
strokinsbc1 strokinsbc1 is offline
Thanks for the fast replies!! I did plan to do a pressure test if all else failed. Several people talk about trans fluid getting into cooling system but ive traced everything down and see no way the tranny is tied into the coolant. And I do agree it doesn't take much oil to look murky but what got me is three times in a row filling with nothing but water and draining after it gets up to temprature every last drop that came out was discolered and very thick(causing me to assume alot of oil got in it) But when checking oil it hadnt lost a bit according to dip stick and not a drop of water in the oil. And the water has the strangest smell when drained and the color is very red, it actully stained the fan shroud red wher it spewed out.Thats when I started searching for other answers besides engine oil. But logically there is no other answer
