Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - this is a real head scratcher...any logical explanation?
Old 07-30-2013, 09:39 AM
oldbogie oldbogie is offline
Originally Posted by strokinsbc1 View Post
And yes its like rusty water but very thick. But it has the weirdest smell thats wat kept telling me there was sumthn different goin on. But I really appreciate all your replies I got a feeling you have solved this mystery. I will pressure test today and check it out a little further. Ill keep you updated!
Check for an engine oil heat exchanger in the radiator or a stand alone unit that will have coolant and engine pressure oil hoses/tubes running to and from it. These are a common way the factory uses to heat the oil in-order to reduce engine warm up time for meeting emissions standards. A leak in one of these exchangers would be engine pressure oil getting into the coolant while little, if any, coolant would get into the oil.
Bogie
