Is It Really a 347?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2003, 03:28 PM
lakecityg's Avatar
I met a guy and we wants to sell me a 347 short block. how can i tell that it really is a 347?
Old 07-17-2003, 03:48 PM
FoxThunder 5.0's Avatar
i think its broke...
well thats kinda tough... does he have any reciepts or anything? are the heads a bit larger than a 302 set of heads? thats the best advice i could give u. otherwise i couldnt think of any other way
Old 07-17-2003, 03:52 PM
lakecityg's Avatar
he doesn't have any of that, but why would the heads have to be any different?
Old 07-17-2003, 03:54 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
a 347 is a stroked 302, look at the crank, and the rod length to be sure...............
Old 07-17-2003, 04:51 PM
woodz428's Avatar
Troll Hunter
Arrow
Since it's a shortblock you should be able to take a tape measure and get a reading from the cylinder deck to the top of the piston on a cylinder that is fully at the bottom. A little crude but accurate enough to determine if it's stroked.
Old 07-17-2003, 05:13 PM
lakecityg's Avatar
so take a cylinder at its lowest point and measure to the top of the deck. ok i can do that but what kind of measurement should I get. what is a measurement range that i would have to be in so that i know it is a true stroker motor?? thanks
Old 07-17-2003, 05:17 PM
woodz428's Avatar
Troll Hunter
Arrow
Stock stroke is 3.00" and the 347 is about 3.4 (without looking it up), so if you get anywhere around that you've got the real deal.
Old 07-17-2003, 05:18 PM
mustang66maniac's Avatar
Ford Freak
a 302 will have a 3 inch stroke, and 347 would have a 3.4 inch stroke...so about 3 and a half inches is what you should get.
