I am seeing just a bit over 9:1 CR w/64cc heads, 0.015 gasket and the piston 0.025" in the hole, 6cc valve relief volume. Stock B&S.
With 628 cc's in the cylinder, 64 in the chamber, 6 in the piston, 3.2 in the gasket and 4.83 in the piston deck, total ingested is 706.03, total squeezed into is 78.03, resulting in a 9.048:1 static compression ratio.
This is a good thing, not a bad thing. 9.0 is an excellent SCR for a daily driver with iron heads. I just finished another post where I railed against you fellows ratcheting up the lift limit on stock L31 heads. NOW HEAR THIS. LIFT LIMIT FOR STOCK L31 CYLINDER HEADS WITH STOCK SPRINGS, SEALS AND RETAINERS IS 0.430". You can't use all the travel there is in there because you have to leave some for safety. Crane offers a torque cam with acceptable lift that would work nicely in this motor at 9.0 SCR. Energizer 260H10, kit part number 100032. 1000-4600 RPM Power range, excellent low end torque, smooth idle, daily useage, fuel economy, 1600-2200 cruise rpm, 8.0 to 9.5 static compression ratio advised. Use with stock converter and stock rear gear. 204/204, 260/260, 110 LSA, 0.427"/0.427" valve lift, timing events -3/27/37/-13. RPM HP TQ 2000 130 342 2500 161 339 3000 206 360 3500 247 370 4000 276 362 4500 294 343 5000 300 312 5500 258 246 By the way, if the piston in this motor looks like the thumbnail, don't count on any squish at all. Oh, and for headers, you said this "mid length headers". You need to use full length headers. This mid length, block hugger, etc. stuff is just a waste of time. You might just as well walk out to the street and throw your money in the gutter. |
You have small cubic inches and heads with a sizeable runner of 170cc and you want to keep low end power in the balance. I would use this cam:
http://www.summitracing.com/parts/SUM-1069/ And as tech inspector suggested, use full lenth small tube headers, if you can get them in 1 1/2 tubes that`s what I`d use. Make sure you get the springs to match the cam. One issue I can see is, if you run thin head gaskets you have to remember, they won`t seal on decks that aren`t perfectly flat. This is why replacement fel pro gaskets are .041 thick. Before I would use a thin gasket I would have the heads and the block decked to assure flatness. Most of the time when someone is doing a 307 build we suggest 416 casting 305 heads as they have 1.84 intake valves that flow better on small bores and small 58cc chambers to keep the compression ratio up. If you were to use 416 heads that would cut some money off the table as there wouldn`t be the need for a special vortec intake or self aligning rockers. While it`s true they don`t flow like Vortecs do with a bowl clean up they will feed all your 307 needs for street duty. |
If ever I was tempted into doing a 307, I swear I'd try a set of 059 L30 Vortec heads:
From the Stan Weiss flow chart: Vortec L30 "059" casting: Lift__Int Ex .100 68 47 .200 128 103 .300 179 138 .400 205 152 .500 221 163 L30 305 head info- POST #487. |
Guys----
I think this is the first thread I have ever seen on this subject that just did not beat the poor 307 to death-----. Someone put a 307 in my 66 Elky years ago, and it is my intent to drive that til it quits. Getting good solid advice to spice it up is helpful. Geeze, even the 64 Chev C-10 I will be building for my son will get a 305. Hell, I might stick with the 250-6 just to irritate the kid
Years ago, before Chevy did the 307, guys would make one to use in class drag racing. Quite illegal and all, but it was done. I'd have rather kept the engine a straight 283/292, but some guys would rather cheat than compete. The point being, is that the engine was a "known quantity" even before Chevy produced the first 'real' one. Quote:
I have a soft spot for that gen truck, though. Had a '65 w/a 230/3-speed stick. For a while it did, anyway.
Thanks for the info so far guys....
To Clarify, I have no problems prepping the 098 heads for larger lift and bigger springs...its just cuts into the budget a bit... Is the 1103 cam out of the question for the 307 in general or because it had too much lift for stock unprepped Vortec heads? I assumed that the split duration and slightly higher lift would help the relatively weak vortec exhaust side evacuate the cylinder better? I also have a set of 187 swirly 305 heads and matching performer intake...maybe I should go that route and save the Vortecs to replace the fuely heads on a future 327 project. Keep throwin ideas at me.... |
tech posted dyno#'s:
"RPM HP TQ 2000 130 342 2500 161 339 3000 206 360 3500 247 370 4000 276 362 4500 294 343 5000 300 312 5500 258 246" Wow that is pretty good for what most call an anchor, the torque numbers are especially good considering. I heard before that these 307's were/are popular in econo rail dragsters...is there any merit to that notion and why |
http://www.iskycams.com/techtips.php Quote:
Heh Heh, Tech I guess you don't have any love for the 187 swirlies huh?...
Sorry guys the Vortecs I have are 906s... fat fingers and a fuzzy memory lead to erroneous info some times. I included a pic of the unprepped set of 906s as well as the set we did with larger exhaust valves, screw in studs, cut for larger springs and .600" lift. etc. These are on my L31 build....I could have the same things done for the 307...probably wouldn't need the 1.60 exhaust valves though... |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| First Motor Build - a Mopar 451 Stroker? | 71gtx | Hotrodding Basics | 10 | 05-01-2009 08:51 PM |
| advice/thoughts/suggestions 327 build | 1968ccaammaarroo | Engine | 18 | 04-23-2009 06:23 PM |
| How much HP? This little 307 really ran strong! | Axelrod | Engine | 9 | 06-28-2003 11:30 PM |
