really need help. brakes dont work! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-05-2009, 05:31 PM
CQNRQY
Loss of brake peddle
I aggree with the guys that a leak is likely your problem and you have already had advise on how to check and repair that.
In the event you have no leaks or air in the system THEN
IT MUST be adjustment at the rear shoes. (measure your drums your shoes should be adjusted to give a small amount of drag) also your drums may be oversize. (this sould help remove some exessive peddle travel.
There is ONE More place you can loose your peddle . IF YOUR FRONT CALIPERS ARE STUCK (not sliding freely) Your piston will have to travel too far for one pump on the peddle. You may have noticed week braking and may have noticed a pull to one side or the other for some time. If it pulls to one side when you brake it will be the opposite side thats stuck. ( check your front pads see if one is almost worn away and the other not waring at all. Their are two small tubes mounted in orings that suport by the two caliper mounting bolts .These tubes should slide in the orings allowing the caliper to centre over the rotor each time the brakes are applied. This allows both pads to apply with minable foot travel
CQNRQY
  #17 (permalink)
Old 03-05-2009, 07:06 PM
T-bucket23's Avatar
Wiki Edits: 26
If it was shoe adjustment, once pumped up the pedal would not sink to the floor.
Chet
  #18 (permalink)
Old 03-05-2009, 09:51 PM
my neighbor thinks something is wrong with the porportioning valve so we are gonna look at that and see
  #19 (permalink)
Old 03-06-2009, 08:39 PM
T-bucket23's Avatar
Wiki Edits: 26
That will not cause the issues you are seeing. If you have explained the problem correctly you have a leak.
Chet
  #20 (permalink)
Old 03-06-2009, 08:46 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I agree with T-bucket23 the porportioningn valve has nothing to do with what you have described in your post.all it does is regulate the flow front and rear.it is a pressure thing so you could adjust it so the front brakes will brake slightly before the rear. cole
  #21 (permalink)
Old 03-06-2009, 09:29 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Start by bleeding the furthest wheel away from the MC. I once had a 80 Chevy truck that I could'nt get the brakes working correctly even by conventional bleeding methods. What I did to get them to work is to gravity bleed them. All you do is open up the bleeders and let gravity do the work. It takes awhile but it will work and is usually less messy that pressure bleeding. Just keep a pan under the bleeder to catch the fluid and keep the MC full. It may take 2 or 3 hours to bleed this way so buy plenty of beer.
  #22 (permalink)
Old 03-07-2009, 08:45 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Probably time to go see a shop about your brakes. Don't go and mess with that proportioning valve or you will have even worse issues.
  #23 (permalink)
Old 03-07-2009, 10:02 AM
ight thanks man
  #24 (permalink)
Old 03-10-2009, 07:50 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
How did you make out with your brakes?
  #25 (permalink)
Old 03-10-2009, 08:52 PM
i got them to work. i gravity bled them and they work good now. thank you for following up and with all your help.
Need Help With My Brakes S10 Racer Suspension - Brakes - Steering 4 01-18-2009 03:00 PM
Stock Monza Master Cyl work with aftermarket disk brakes? Quarter Flash Suspension - Brakes - Steering 1 11-19-2006 06:31 PM
left side brakes wont work racur96 Suspension - Brakes - Steering 1 07-22-2006 04:32 PM
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 09:57 AM
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 09:42 PM
