reaming quadrajet idel ports ?
so as you all who followed my before about the quadrajet i cleaned up again and such running super lean at idle, you guys said it needed to have the idle ports reamed out ( not the mix screw holes but the brass plugs in the carb base )
since im getting a solid 8 mpg with the suburban now i think this would be a good time to maybe see if i can get the quadrajet fixed and use it as a test??!!
ive drilled out jets for our methanol gokarts and such so as long as i got the correct ream i think i should do okay.
so does anyone know the start of seeing what ream i would use or info as how to do this kinda thing ?
