reaming quadrajet idel ports ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-01-2012, 07:22 AM
Originally Posted by DoubleVision View Post
If the spark timing is too low, the idle has to be opened up so far to get it to idle that it pulls fuel from the boosters and not the idle circuit.
You have to remember, you only have so much room for the butterflies to be closed enough to run off the idle circuits. If the timing is set too low then the further the idle speed has to be opened to compensate. When it's off the idle slots in the base of the carb it pulls fuel from the boosters to idle, and this makes the idle mixture screws unresponsive. Thats why I need to know what the base timing is set at and if the vacuum advance is in use.
the truck is running right now... i have a eddy carb on it and ive been driving it like this for the past few weeks, im interested in the qjet because of more mpg.
i dont think timing is off, i went through those steps i found on here and many said it was a great thread. the truck atm idles at 600 rpm and i get 8 mpg, the motor is really smooth with the eddy, which is why i feel my issues is with the 1975 qjet
  #17 (permalink)
Old 09-02-2012, 03:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Info on timing and setting up an advance curve is here.
The '75 Q-jets VERY often used the "aneroid" set up or a spool affair that replaced the aneroid as a part of the APT (adjustable part throttle) calibration. These carbs are not what I would pick for performance OR economy- but if that's all you have and you cannot or don't want to get a different core, you're options are to either use the aneroid set-up or to disable it and tune it like a "normal" Q-jet.
Some info on the aneroid is here.
Good luck.
The Following User Says Thank You to cobalt327 For This Useful Post:
LEROYDOZOIS (09-03-2012)
  #18 (permalink)
Old 09-02-2012, 07:07 AM
If your Quadrajet is from a '75 truck, don't get confused by reading information about the '75 Quadrajet used on cars. Carburetor changes in the trucks lagged behind, so your carburetor is equivalent to a pre-75 carburetor used on cars. That is not necessarily bad, just confusing when you read articles about Quadrajets tuning.
GM continued to delay truck carburetor upgrades for several years. I decided to not rebuild my '75 Quadrajet, and use a core from an '86 1 ton GMC truck. This is an APT carb, and the last version before they added any electrical connections. However, my carb is equivalent to what they started using in 1980 on cars, since by '86 most Quadrajets in cars had at least one electrical connector.
Bruce
The Following User Says Thank You to 75gmck25 For This Useful Post:
  #19 (permalink)
Old 09-03-2012, 07:28 AM
Good luck.
theres nothing like that on my carb... it even looks scarry lol
  #20 (permalink)
Old 09-03-2012, 07:30 AM
Bruce
i gotcha, i figured it wasnt the rods after i thought it through, ill start with the stuff i ordered and see where the truck sits. i just want MPG, no need for extra power when ur talking 454 lol
  #21 (permalink)
Old 09-03-2012, 02:14 PM
So I'm no guru or anything, but I have successfully set up a q-jet for a street performance small block. I ran into the same problems with the idle circuit you're having, instead of large displacement causing the issue it was a larger duration cam (242@.050). You've already drilled out the the base plate where the idle mixture screws set in right? How big did you make those holes? I did mine at .090. You might have to shorten the springs on the idle adjustment screws if you can't seat them all the way. That alone won't really fix anything, the real restriction is further up stream. Take the top of the carb off so you can see down into the fuel bowl etc, remove the accelerator pump and then lay the gasket back down. Look in front (towards the front of the car) of the primaries and you will see 2 kidney shaped spaces in the gasket in front of each primary bore. There are 2 brass restrictions in each kidney. These act as the idle channel restrictions. The hole further towards the back is the idle down tube, the one towards the front is a press in restriction. Measure the restriction and drill it out .004 or .005 bigger, don't go nuts bigger. Take the baseplate off and clean out those filings you just made. Put it back together, go 2 turns out on the idle adjustment and see if it idles any better. If not you might need bigger idle tubes and need to enlarge the idle air bleeds. Try this first though, it should help richen the circuit up.
  #22 (permalink)
Old 09-03-2012, 08:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Then your carb will look similar to the one below (there are many small variations- what I'm referring to is the basic castings):
And not like the carb below (note the conical looking casting on the passenger side of the air horn- the aneroid would be under it on '75 carbs, although the casting remained this way even after the aneroid was discontinued):
The "early style" carb at the top was used until the '90's in marine applications and was also used at the same time as the "later style" casting at the bottom in some applications.
  #23 (permalink)
Old 09-03-2012, 08:58 PM
yeah,
u hit the nail on the head, i got the one ur finger is on.
Spindle reaming Intense RT Suspension - Brakes - Steering 2 01-23-2010 01:01 PM
Rough Idel Of a chevy 350 likemike Engine 3 04-20-2009 05:32 PM
302 ford knock at idel cliff tate Engine 1 06-08-2008 09:36 AM
Identifying Quadrajet Ports on throttle body... flipp121 Engine 11 05-19-2005 09:27 PM
idel speed affect timing?? smlblcks10 Engine 3 04-14-2004 05:15 PM
