rear 3 link setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2010, 11:54 AM
rear 3 link setup
IM DOWN TO THE LAST PART WICH IS INSTALLING A THREE LINK SETUP IN THE REAR.I DID NOT KNOW THAT THEY WERE SO EXPENSIVE $300 + dollars ...yikes.maybe for some of you thats pocket change but for me its three pockets full and a smile hahaha.im building a cheap low buck hotrod what are my options besides this.please help a greaser in need.
Old 05-15-2010, 10:12 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Not certain I understand. If you want setup info for a 3link, go to pages 18 and 40 of my site. If you want suggestions for options...instead of a 3link..., that's another matter.
You should be able to save some money...if you're a fabricator...by using stock links and bushings and fabbing your own brackets.
http://www.racetec.cc/shope
rear sway bar 4 link theccrider Suspension - Brakes - Steering 6 08-08-2008 08:00 AM
How to setup gm rear end dpjim2 Transmission - Rearend 3 02-08-2006 08:43 AM
4 Link rear suspensions Black-Hawk Suspension - Brakes - Steering 3 01-06-2006 08:30 PM
Rear suspension/shocks setup for drag use? 46ChevyPickup Suspension - Brakes - Steering 2 01-09-2005 05:14 PM
four link rear suspension dorseytoottoot Suspension - Brakes - Steering 3 10-22-2002 04:48 AM
