rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2005, 05:16 PM
ss396si's Avatar
rear
hi
can the rear be removed on the ground? i have to jack stands supporting the car. has anyone attempted this?
thank you
Old 02-28-2005, 05:21 PM
pro70z28's Avatar
Last journal entry: "Z" construction
Originally Posted by ss396si
hi
thank you
Do you mean pulling the rear end apart or taking the whole thing out of the car? Either way no, the axles have to be pulled out far enough the get the center section out. so the rear wheels can't be on the ground.
Old 02-28-2005, 09:56 PM
What kind of vehicle?
Old 03-07-2005, 02:36 PM
ss396si's Avatar
i have a 69 chevelle. i plan on puttin boxed lower control arms for a sway bar and maybe uppers. its also a open rear 10 bolt,i plan on makin it a posi unit. im kind of new to restoring cars. im doin it in my backyard,can you do this with jackstands?
thank you
Old 03-07-2005, 02:43 PM
poncho62's Avatar
Wiki Edits: 5
With the stands under the frame, you still need a jack of some kind to support the rear end when you take the trailing arms off. A good floor jack is a good investment.
Make sure you have good solid stands and jack. You will be working hard under there to get it apart and could possible knock it off or collapse cheap stands.
Ontario Rodders
Last edited by M&M CUSTOM; 03-07-2005 at 08:44 PM. Reason: I fixed the bold and underline problem
Old 03-07-2005, 05:25 PM
ss396si's Avatar
i have the 6-ton jack stands from summit and a good 3-ton floor jack.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
