rear air shock help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2003, 07:56 PM
Last journal entry: Rear End Disassembly
rear air shock help
i have a 71 plymouth gtx with 295/50/15 tires in the back. i have air shocks on this car, and they are a little old. the problem is that whenever i put weight in the car other than myself, the tires will rub on the quarter and this is causing a major problem. even if i add more air to the shocks, this will still occur. Can the air shocks be bad, or will they always sink when weight is added?
Old 09-08-2003, 11:33 AM
air shocks
Whew! that is one serious tire size!
Others on this board may have had different experiences but mine that if the air shocks are leaking it will usually be around the fittings, especially at the shock. At one time you could buy a fitting kit to replace them. The kits had tubing and the tiny plastic "o " rings. I dont know if the kits are even available anymore?
Hope this helps
Old 09-08-2003, 12:53 PM
Airshocks........? they still make those
Old 09-10-2003, 03:57 PM
bullheimer's Avatar
NEVER use credit cards!
i would go with wheel7's advice. yeah they still make'm you knot-head! gabriel hijackers. wanna see some? look to the left
Air Ride Tech?? obviously you are a non-believer!
Old 09-10-2003, 04:30 PM
A non believer in what?
Old 09-11-2003, 12:17 PM
IMHO, you should ditch the air shocks altogether. The shock mounting points on the rear of the car were never meant to suport the weight of the vehicle. You can get new springs from http://www.espo.com/ in 1 inch and probably 2 inch of extra lift to clear your tires...
Old 09-11-2003, 12:48 PM
DragTour69XL's Avatar
Galaxie Man
Question
Or just have Tony hook you up with air bags
Old 09-12-2003, 11:35 AM
Kevin45's Avatar
Just one of the guys
You can still get air shocks and hose kits but bags would be the way to go. Last a lot longer and a lot tougher. Nothing worse than be cruising and pop a shock and have to limp home with a tire rubbing.
Kevin
Old 03-23-2006, 12:01 PM
air bags?!
What in the heck are air bags (refering to using these instead of airshocks)?
