VERY VERY NICE WORK! thanks for posting those photos, you work clean and on a budget, I like that 10X more than your high buck hot rods.... This is not criticism just a word of caustion (for your agrivations sake) I noticed your using the festo fittings on your bags... (this is just my personal experience) I have helped multiple rodders in my area get rid of their festo's all of em work great for the first little while but it seems like as the vehicle gets more time under its belt (driven) the vibration and pressure cycling tends to make em leak, and I'm not talking about a onsey twosy leak....for example the most recent truck we converted to brass pressure fittings. When the truck was first built it would hold its pressure for over 5 days, a month after it would cycle the compressor on after 1 hour....thats some serious leakage. we changed the festos out....no problems....just keep an eye on it...beutiful work!
I agree, very nice work. My only concern would be the poly bushings with the rather large lateral distance between the rear mounts of the upper links. The total elimination of binding while cornering, with a triangulated 4link, is only obtained with a true "V" arrangement. I'd suggest you monitor the wear on the poly bushings and, if excessive, switch to rubber.
Very nice work. I like how you used a HUGE single exhaust to clear all of it. It sure does look very well packaged. It looks like your front wheels could use a bit more backspacing to help out the steering geometry.
How much does your camber and caster change with ride height? I think you will have a very small range of where the front end can be while driving and not kill the tires. Quote:
The binding because of the bushings would be the same for any other 3 or 4-link suspension (3-link binding less only because it has fewer bushings to twist). The recent way the factory has gotten around this is to use bushings with voids in them to reduce their influenced on the roll stiffness while still keeping the same front to back stiffness. ...but hey. Just think of it as already having an anti-roll bar on the back end |
I was going to ask what body you were going to put on that work of art...but then I looked in your project journal...The body looks even better than the chassis. Too bad you live so far away. I would love to see that thing up close. That truck has it all (I wasn't expecting to see a truck body)!
A triangulated 4link is essentially a 3link with the upper link splayed out to accept lateral loads. But, the more you separate the link ends at the crotch of the "V," the more it begins to bind like the competition 4link. I considered the suspension pictured to be "borderline," as far as causing trouble is concerned, hence my warning. |
Kallie49
Thanks for the tip on the fittings, I assume you mean the plastic push fittings. So far no problems - the were all the local supplier had at the time, I've found it hard to come across anyone locally who is dedicated enough to stock or supply a decent range of fittings.
To; Triaged, re- front suspension
Yes, camber and castor does change as it does with all Fords with the twin I-beam front end. With the stock coil springs you have no control over ride hieght and over time as they settle, tire wear can be a problem - even carrying a load affects the front end ride hieght. However, with the air springs you simply adjust the pressure for optimal geometry and go with that, and if it is too high a pressure for a good ride, simply shim the lower mount to change the operating range of the spring and change the bumpstop hieght accordingly.
To; BillyShope re- rear suspension design
As to my setup being of a "borderline" design, I would say take a look under countless Ford, GM and Mopars sometime. They all have used variations of this design. Mine works and tracks just great, thanks.
AirRide
CCRodder,
Very nice job on the frame etc.. I was wondering if you are going to use any type of load leveling device? I bought an AirRide Pro e system last year and have installed all of the hardware but the body is still not done so it's not on the street. AirRide came out with a leveling system but guess what, it won't work with the Pro e, only the Pro e 2 system. Of course for another $1200 you can change the old to the new. The old hasn't even left the shop yet and I don't feel like shelling out that much money for something I already have so I was wondering if you were using anything on your project? Thanks, Jim |
Load levelling
Nah, I wasn't going to use a load levelling or "memory" system. More gizmos and wiring to mess with. I kind of just like to play with to ride hieght manually rather than giving over control to the evil computer...
Quite honestly (and I asked these questions when I put mine in cause I was looking at the computer memory systems as well) I was told to drive it without the memory system in place, get used too it and then make a decision on whether or not to install it....once you get used to your system you just know where you are sitting relative to your suspention, seeing as I was advised that the more fittings and sensors you have the more that there is to leak and maintain (and to brake which makes perfect sense to me anyway) I chose to not install the computer stuff....plus that kinda gear gets really expensive really fast....thats just my opinion tho...each to his own
| Help...rear suspension design questions | FrankR | Suspension - Brakes - Steering | 1 | 06-02-2006 07:50 PM |
| independent rear suspension | truckboy | Suspension - Brakes - Steering | 6 | 05-25-2006 11:33 AM |
| air ride suspension | PaulNJ53Ford | Suspension - Brakes - Steering | 6 | 01-13-2006 02:45 PM |
| Orange peel in the clear | Montypierce | Body - Exterior | 13 | 03-06-2005 08:49 PM |
| homemade rear suspension | zonk | Suspension - Brakes - Steering | 2 | 02-22-2003 02:16 AM |
