rear axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2005, 11:38 PM
rear axle
I have a 54 chevy truck,5.0 chevy engine 3 speed box,truck does about 70 mph,I want to change the rear axle,I think its standard truck axle,any advice on the way to go would be much appreciated.thanks.
Old 05-21-2005, 11:56 PM
As one of the Moderators .......
Let me be the first to WELCOME YOU...
If your truck has the stock enclosed driveline.........it will require a good bit of work and parts. Parts that, no doubt, will be difficult to find in England. If it is a open drive.......then it is a LOT easier....and a later model GM 1/2 ton rear end with 3.08 gears will help a lot.
Need more info on your truck.........
REAR AXLE WIDTHS joegaddy Transmission - Rearend 6 12-17-2005 09:30 PM
Rear Axle decode Scorpion8686 Transmission - Rearend 1 04-01-2005 08:09 AM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 12:05 PM
Width of S-10 rear axle? Dreamweaver Transmission - Rearend 1 02-28-2003 01:51 PM
Jag Rear Axle -- almost completed! farna Transmission - Rearend 5 02-28-2003 08:55 AM
