rear axle ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2005, 08:36 AM
noobie
Last journal entry: Boy am I slow!
rear axle ???
OK first off , Thanks to all here who have help on my other question thus far !!!!1
OK ,What is the width of your rear axle in YOUR T-bucket?
Wheel mounting surface to wheel mounting surface.
Thanks!
Gr8lite
Old 08-20-2005, 06:28 PM
When dealing with 5 lug wheel rear ends that are common and popular....
The most narrow 8 inch Ford rear ( non narrowed ) is a V8 Maverick ( 5 lug wheels ) ..........and it is 56 inches.....measured this way.....
The most narrow 9 inch Ford is a 57 to 59 Ford .....about 57 and 1/4 to 57 and 1/2 inches.......measured the same way.
here are two popular Ford rear end sites.......check then out....
http://www.dfwmotorsport.com/Fairlane/9inchrearends.htm
http://www.kevinstang.com/Ninecase.htm
I always use a 9 inch Ford.....the 8 inch is weaker, has less gear options from Ford and has less parts support. The 8 inch was never installed in anything Ford built with over 250 to 260 rated HP. More than that....Ford put the 9 inch in it.....
Good enough guideline for FOMOCO........good enough guideline for me.....
REAR AXLE WIDTHS joegaddy Transmission - Rearend 6 12-17-2005 08:30 PM
Rear Axle decode Scorpion8686 Transmission - Rearend 1 04-01-2005 07:09 AM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 11:05 AM
Width of S-10 rear axle? Dreamweaver Transmission - Rearend 1 02-28-2003 12:51 PM
Jag Rear Axle -- almost completed! farna Transmission - Rearend 5 02-28-2003 07:55 AM
