Rear axle for AD truck
Hi Guy's,
I am building a rod along the same lines as Centreline. He recommended using a '78 Camaro rear axle. I have the chance of buying one from a '73 Firebird Bullnose. Are they at all similar or should i avoid it? We are not exactly spoilt for choice in the UK. |
As far as I know all the Firebird and Camaro rears of the 70s vintage should be the same width and have the same spring perches. Someone please correct me if I'm wrong.
Centerline |
That's my concept of those cars - made of the same parts except for different rubber front and back bumpers and different name plates.
Both cars used the GM 8.5 inch 10-bolt axle from 73 to 81, it should have the exact same spring perches and everything else in the same measured dimensions.
I used a camaro 1977 rear diff in my 48 chevy... it was a 3/4 ton truck.
the back frame is different from a 1/2 ton truck
At the Bonneville Salt Flats, first gear is known as 130 mph. |
How many ponies can that rear end handle? I'm building a 400hp+ engine to drop in a '41 Chevy p/u and been looking at my options. Any suggestions?
Thanks for the help guy's. Top job as ever.
Darren, Did you get that rear from the camaro. I used one from a 75 and I had to remove all of the hardware that was welded to the axle and place new spring pads for the narrow spring in my 55 1st series, but if you are changing the springs and hangers it should fit. The width is correct but as mentioned a nova or Monte Carlo is 1 to 2 " narrower.
Hi Solidaxel,
I am fitting a 4 bar setup with bags so all hardware will go anyway. Cheers for your input. Darren. |
Darren what gear box are you using?
here is what I am finishing up |
Hi Solidaxel,
I am using the TH350 that came from my old C10. Just got a Camaro backend today, plus dropped spindles and an Impala steering column in exchange for truck bits i don't need. Will order Mustang ll front crossmember soon. Cheers, Darren. |
Have you installed the M ll front end yet !!!!
