Rear axle bearing play - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2002, 10:19 AM
Seon's Avatar
Post Rear axle bearing play
I replaced the rear bearings on my '70 Chevelle and decided to measure the up and down play with read .010"-.015". No signs of wear on the axle and the old bearings looked fine. The reason why I decided to change the bearings was because I was getting a shimmy at 50-55 mph. I had the tires balanced twice, replaced front wheel bearings and both u-joints on the drive shaft. I called a couple of shops, one local shop said he's never measured the play the other, Currie Enterprises of Anaheim, CA said he didn't know. Is this play normal?
Old 12-11-2002, 12:24 PM
4 Jaw Chuck's Avatar
Post
Straight rollers will have a certain amount of clearance, 0.010" sounds like a lot though. I would be inclined to say that 0.005" is a better new parts figure.
I would replace them especially if your putting some big power to the rear wheels.
— Han Solo
Old 12-11-2002, 04:54 PM
Seon's Avatar
Post
Thanks for the reply. That's with the new bearing.. .010"-.015" play. I'll run them like for now.
