Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear Axle Bump Stops
Old 10-28-2012, 12:50 PM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
sedanbob
i used those same bump stops on my truck
not a good pic but i welded an angle bracket on the side of my frame next to my c-notch
i have about an inch of rubber below the c-notch, i hit them hard occasionally, they do their job well
any oem bump stop appears as hard as a rock and are usually a lot wider
these are progressive by nature of the taper
The Following User Says Thank You to ogre For This Useful Post:
sedanbob (10-28-2012)
